I'm fighting some significant black algae, and using aggressive wire brushing. I'm getting visible clouds of debris as I brush - that seems to be pool finish material. The finish itself is some kind of exposed aggregate, and is already very porous and rough in many areas. The pool is 19yrs old and assume finish to be original.
Is this a sign of some other problem? Should a wire brush be safe for use on any in-ground finish?
PH 7.6, Calcium 300, Alkalinity 60, CYA <20, Chlorine at SLAM
Appreciate any help.
