I have a curious question on how to winterize pool drain lines.... So I know you have to put air pressure to the system to drain water out, it seems easy on the return lines and skimmer lines since these will be below water level.... But what about drain lines? once you get the majority of the water out, you basically cant fully take the water out because once you turn off your compressor, water will rush back in because of fluid mechanics... I draw a little picture to explain what I am asking...
