I'm thinking its about time to turn off the solar for the winter. This is my first winter with it and I want to make sure I do everything I"m supposed to, very nervous that if I don't do the programming correct on the SunTouch controller I'll end up with my valves causing a dead end and breaking something.
1. fully drain the solar panels at low points, leave open
2. turn valves to block the to and from lines up on the roof
3. Program the SunTouch controller (here is where I'm super unsure) - Do I change it in the solar menu, the circuit menu? Do I need to change the valve menu at all?
Link to my controller just to make sure SunTouch Controller
Anything else I need to know or do for the winter
