- Dec 13, 2020
- 905
- Plaster
- Jandy Aquapure 1400
Hi all. We're in North Carolina, Chapel Hill. Moved in this past summer. The pool has four Pentaire Deck Jet IIs. They hadn't been used for 7 years. After fixing broken valve actuator wiring, they worked fine. Joyful to see.
We're keeping the pool open for the winter. I blew out the jets to avoid running them on cold nights. But for two, the cups around the nozzles do not drain, though there' supposed to. Installation manual here. Best I can tell by probing through the drain holes with wire, they're embedded in mortar. (The deck is sandstone flags.)
Now something that was confusing earlier makes sense. When I was getting them back in operation, I found the balls of those two nozzles popped out of the sockets. Thought that was weird. Now I see they must have been forced out by rain that got into the cups and couldn't get out before it froze.
I'm wondering what I can do about this. My best thoughts:
Funny. The pool was installed by a company that's been around for at least 14 years with a great reputation. But I keep finding things that just aren't quite right...
- Coil some "closed cell backer rod" in the cups. This is the stuff used in pavement cracks to fill space under the rubberized caulk. It's advertised to displace water that wants to settle in the crack and allow ice around it to expand with no harm. Seems like this might help a lot. But that's a guess.
- Get a long masonry bit and drill through the drain holes through the mortar into dirt. This might be a nice fix if the soil is free-draining, but could end up drilling through a pipe, which would be a disaster.
