I have an above ground pool that was closed by a pool company before winter. It is covered and was drained downed below the skimmer. I’ve recently heard water coming out, and I can see it coming out the return line I’m guessing that the plug has come out and water is being displaced because of the ice on the cover. I’ve tried as much as possible to keep water and ice off the cover, but this year has been more challenging than the most. I had hoped it would melt enough today as it close to 50 degrees, but still not melting enough to pump off any water. We have a few days above freezing ahead but nowhere near 50 and still getting to freezing some nights. Before posting here I contacted the pool company and they said the best bet is to just wait it out, but to try to keep getting the ice and water off the cover.
My questions to the group are:
- Is there any safe way to speed the melting process such as salt or a way to heat it? I have seen mats that people use on ramps and walkways and wondered if there was something similar for a pool cover.
- I know that typically you should divert water away from the pool. However I’m hesitant to attach a hose in case we freeze again. What do you suggest?
