We are in a coastal southeastern climate where it may freeze but it is rare - we only had two days with frost last year and no hard freeze but several years ago it was lows in the 20s for 3 days. But I just looked at winterizing process and it doesn’t seem worth it.
We haven’t swam in about a month, the water temp is ranging low-mid 70’s so mostly we are just wimps. Our swimming season will probably be May-Sept but we’re looking into a heater to extend that. Would have gone in today if the water wasn’t so chilly! I have a solar cover and a leaf cover, but don’t know how to attach the leaf cover, it’s just floating on the surface right now. I’ve been putting chlorine in periodically and check the pH.
*Can I cut the pump run time down? It’s running about 8 hrs daily right now.
*What do I do if it is going to freeze over night?
*How do I attach the leaf cover?
*Do I just keep up with the chemicals like I would if we were swimming in it?
*Should I remove and store the solar cover?
thanks for any help!
