Thank you very much. I was able to get the neighbors hose so that should cut down about 5 or 6 hours of fill time. I am aiming for 8 to 9 in the morning for the pool to be filled. We will get the pump going add some chlorine and the pump and filter should be able to run for 4 or 5 hours before all the rugrats start to show up!
My pH is still high and I picked up acid to lower it. I also picked up acid to raise my CYA. Should I just add the chlorine, and wait until Sunday to add the pH reducer and conditioner? Or should I add the pH reducer (I was told to place it in the skimmer?) once I have the pump and filter running
