- Feb 12, 2021
- 8
- Vinyl
- Intex Krystal Clear
Last week-end I made a DYI solar heater from 5/8 black irrigation tube. Th system is a separate circuit from the pool pump. Its pump is submersible and I am planning on turning on and circulate Friday thru Sunday before we expect to use the pool.
The pump is manual and likely not rated to sit in salt water continuously. (Superior Pump 91014 Thermoplastic Oil-free Utility Pump).
The question is: Will the algae grow inside the black tube sitting in the sun without circulation over the 4 days when the circuit is not on?
Thank you.
Thank you.
