Will adding Calcium chloride increase the salt level as read by my SWG?
Tbefi1
0
Mar 30, 2018
10
Austin / Texas
Latest chemistry: FC = 7.5, CC = 0, PH = 7.7, TA = 75, CYA = 40, CH = 225, salt = 3100, temp = 68, CSI = -0.36 (pool math).
Based on this I need to raise the CYA and CH.
My questions:
1 - Will my salt concentration as measured by my SWG sensor increase when I add 35# CaCl? If yes, is this 'useful' salt to the SWG or will I need to recalibrate it?
2 - Once I increase CH to 350 and CYA to 70, my CSI according to Pool Math will be -.25. Is this a good CSI? The biggest lever to get CSI closer to zero is to raise PH, but that is bad for the SWG and also swimmers eyes. BTW if I decrease PH to 7.5, the CSI goes to -0.43 which is getting close to the -.6 limit. What is the correct CSI to shoot for?
Thanks!
Tony
50 lbs calcium chloride is approximately equal to adding 40 lbs sodium chloride.
A pH of 7.8 is usually a good choice.
A CSI between -0.3 and 0.0 is usually a good choice.
Be careful about overdoing the calcium. If your fill water is high in calcium, the level will rise with evaporation and refill.
Also, as the water warms up, the CSI will go up. So, plan for the highest water temperature that you will get.
