This has been a very interesting thread. I understand the original post is over a year old, but it raised several questions I did not see addressed.
seilsel said:
I've done 7 swamp-to-pool conversions pro-bono for the sake of knowledge, with all the work entailed, since I started in this industry.
Of these seven pools (4 of which were above ground), only one was cleared up via the bleach method with constant testing. It required a lot more bleach than was recommended, and I worked it out to determine that the bleach was about 4% active.
The others came out to about 2-3% active chlorine. The other six pools I gave up on and was able to clear up with one 30ppm dose (volume/10k x 1.8 x 30 = oz) of cal-hypo, plus all of the manual labor involved.
I did think about using Cal-Hypo to boost my chlorine level quickly then follow with constant monitoring and adding liquid chlorine to maintain shock level.
seilsel speaks as if he does not "constantly measure" if he's using cal-hypo. If the bag says "treats 10,000 gals" he throws in the right amount for his pool, then walks away.
He also stated that after giving up on 6 other pools, shocking to 30 ppm one time cleared the pool up.
Neither of these stories mention the CYA level or the CH level.
And as far as I can tell, the only method used to determine if the job is complete, is the eyeball test.
But we all know there has to be more than that right?
seilsel said:
Thank you, internet water chemistry ninjas. I understand that the active chlorine numbers are subject to a wide variety of problems; I did the best that anyone could. But the simple truth is that the cal-hypo clears it up in a day whereas the bleach required days of testing and dosing.
Assuming this is true &
seilsel does not have to "follow" up on these pools... how can we explain this phenomenon?
Perhaps he is overchlorinating, to 30ppm when he only needs 12ppm? So he is actually above shock level for hours. Then the pool is using a SWG that is set at max, constantly maintaining FC above 12ppm for an extended period of time?
But, even if that were the case, why wouldn't he get the same results with a 30ppm dose from liquid bleach?
