I'd say over 2 weeks now when I noticed the water was very cloudy. This was after my previous SLAM, which I may have ended too early.That's a lot of work! How many days have you been doing this?
Hmmm no I realize I've been backwashing / rinsing / refilling a few times since I last checked. It may have dropped down, but it was above 40 and right below 50 when I measured. Lower CYA is better from my understanding for SLAM, so I'm not concerned unless I should be?Are you confident about your cya level?
My gosh, thank you. I had to get both bulbs replaced and a combination of hesitancy and fear made me leave it to the pool guy. This guy charged me a buncha money to replace these bulbs and on top of that the bulbs weren't screwed in well and were loose.If you’re slamming for 50ppm cya you’re coveredkeep slammin till no more dead stuff reoccurs!
Here’s a video on the light- he’s replacing the bulb but it shows the process
Still no way to vacuum to waste?Brushed 10 hours apart today, still brushing up semi-thick clouds even though the pool is crystal clear, pool fc dropped to 14 today around 8PM
That cloud of dust from behind the lights is hidden algae, so great job finding that. Time will tell if that is the only hiding spot or if there are any others.So I don't vacuum to waste because I didn't see that in the SLAM guide. I finally took out the lights a couple days ago and a cloud of dust came out as I brushed inside. However now my pool is cloudy again, I feel my SLAM has been cloudy this whole time even weeks later, it finally got clear the day after I opened the light, and then the 2nd day after water's turning cloudy again.
I just shocked back up to 21 this morning for CYA 50. Stairs are removed, Lights are removed. There's nothing left in my pool besides drain covers, and I don't know if I can hold my breath long enough to remove a drain from 8 feet deep
I've been shocking this whole summer, clearly I'm doing SOMETHING WRONG
