I would add another 10ppm of CYA or so and start to SLAM it with bleach.
What is your pH?
What is your pH?
A couple things:
On the alkalinity. That 3 has me puzzled. Did you multiply your drops by ten? My guess is you got a 30?
Your pH is probably LOWER than 6.8. That's the LOWEST your gauge will read ;-)
You HAVE to keep that FC up or you will never conquer the green beast. As said above, check it hourly and keep adding to keep it up. If you can't babysit it all day, I have found much better luck babysitting it at night...after the chlorine eating sun has gone down.
Get you a good leaf net and scoop the gunk off the bottom...just go blind at it, you'll get tons! I've even been desperate enough in the past to climb on in that booger so I can feel the debris with my feet.
Lastly, I'm an old pool owner but learned a new lesson recently. Like it appears you didn't do, I also didn't use a winter cover this past year and it cost me a liner. While discussing with a coworker who grew up installing pools for his dad's business, he said something that made complete sense to me. Uncovered, your liner is exposed to the elements/sun 12 months a year. Covered in our region, it's exposed about four months. I think that may be the key to liner longevity. I've only got five years out of last two liners. I'm going for ten this time..with a winter cover!
Good luck!!
If FC is above 10, the pH test will read falsely high. So ignore pH during the SLAM. That's why we say to set it before you start, because you won't be able to play with it once you get going.
pH is easy to fix, in minutes even, after the algae is gone.
Since you're starting out so green make sure you check the FC about an hour after you add bleach. (Provided you are at home to babysit the pool today.) The more often you can test/dose in the beginning the faster the process will go. That will also help you get to the point where you don't have to test it so frequently because the FC will start to hold a little longer. A weekend is a great time to start!
Happy SLAMming! (well, you'll be happy when you're done! lol)
If you are SLAMing, your FC is way too low. 4 is barely the minimum.
You're SLAMming to get rid of the green, right?Based on what I had read, I thought this was the "target".
CYA 30
Min 2
Target 4
Shock FC 12
Post #27 from Divin Dave said to use those numbers. I didn't see any numbers in your last response. Is there a different target number I should be aiming for? Where did I misunderstand?
Following this thread too....don't be hard on yourself...I've real Pool School 20 times and will prob need to read it 20 more. Only way I learn is by doing! These guys have the patience of jobe!
