We re-tiled the pool last year...from below the water line up to the coping. I am noticing now two places near the elevated spa waterfall opening (splilway overflow in to the the main pool) that have a 2-3 inch long white crusty buildup in the vertical grout lines of the tile. Since the grout is also white, it is not to noticeable unless you are close. I have seen these in the past near spillways on other pools...and am assuming it is related to the splashing and/or churning or the water. You can definitely feel the elevated rough bumps with your fingers.
So, I am aware that MA will remove this, but am looking to see if there is something more gentle...or maybe I can start with a 10% solution MA/H20 and work my way up to stronger if it does not come off.
I'm sure this is a pretty common problem. Didn't find it in other posts
Thoughts?
Thoughts?
