We have a fibreglass SWG pool with travertine tiles around it.
Recently we had a lot of rain and the pool filled right up to the tiles for several days before i had a chance to backwash.
A few days later i noticed 3 or 4 'drip' spots directly below the grout joins of the tiles - where there were dried white marks on the fibreglass above the water line.
i scrubbed them with the pool brush and a rag, and i’d say it’s half gone - yet some have remained/come back. (they 'disappear' when you splash water on them - but you can feel the rough texture with your finger remains)
I’m guessing this is most likely grout efflorescence right?
Confirming - the marks only appeared after the recent heavy rain and water level reaching right up to the tile level.
water readings are currently:
FC 5
CYA 70
PH 7.6
TA 50
Salt 3800
CH 225
SWG running at 20% for 3hr40min a day (its only spring time here in Australia)
water is clear and has been for about 10 months.
I have a few questions...
In terms of cleaning them off:
I’m hesitant to use diluted Muriatic Acid to attempt cleaning these marks for 2 reasons, A) I don’t want to damage the gel coat B) I’m nervous about handling small quantities of MA, and splashing it around trying to get a 1:4 solution with water. Dripping MA on the tiles makes a fizzing sound and scares me, letalone what it must do to the gelcoat. should i be this concerned? any tips for handling?
As a less brutal alternative - I gather plain vinegar used undiluted might be a less severe way to try removing these marks? Is that safe/safer to spray onto the marks and try removing them? i’m thinking I could try spraying and leave for a progressively longer amount of time to see the least amount that will get the marks removed.
In terms of stopping the marks coming back:
The travertine tiles were sealed initially with this product - but i may not have got the sealant right in up there to the underside. Will extra coats of that product stop this problem reoccuring - or is there any way to stop it? I was thinking perhaps some sort of resin/glue could be used to really seal the underside of the grout and stop the water splashing up in under there. Any tips/ideas?
Heres some pics. Any help appreciated - Pete
FC 5
CYA 70
PH 7.6
TA 50
Salt 3800
CH 225
