Yes. White flakes from an SWG are almost always scale. What else could the white flakes be?
Yes. Inside the SWG cell, when it is generating chlorine, the pH increases strongly due to the formation of hydroxide ions. The pH increase from the chlorine generation process will eventually be compensated for by all of the acidic chemical reactions caused by chlorine oxidation and disinfection, as well as the formation of hypochlorous acid from the dissolution of chlorine gas. But, in an instantaneous sense, the pH inside the cell is high. It can go as high as 10 to 11. This is why salt cells scale up - because the water that flows through them almost always has appreciable amounts of calcium and carbonates in it.
My suggestion was to simply use some diluted MA (20 Baume or 31.45%) to make the test safe to perform with fewer fumes. Full strength MA is not fun to play with outside of a fume hood.
It is possible to get all three scaling types if all three anions are present in the water (carbonate, sulfate and phosphate).
If you’d like to read a short, 2 page primer on the chemistry of calcium scale, this technical bulletin from Dow Chemical is interesting -
Search
It’s not just the calcium ions that matter, it’s BOTH the concentration of the cation (calcium) and the concentration of the anion (carbonate, sulfate and/or phosphate) that matter. You need enough of both chemical species to exceed the solubility product of the resulting scale compound. So, if water has high CH, then one can keep the carbonate anion levels lower (as measured by TA) to compensate. In my pool I have had CH levels as high as 1500ppm but no scale...why? Because of I keep my TA at 50ppm (with a CYA of 90ppm and borates at 50ppm), then my carbonate level is so low that’s it doesn’t matter. But here’s another interesting fact - I have gotten sulfate scaling from my SWG cell...why? Because I had my pool tiles cleaned by kierserite blasting (kierserite is magnesium sulfate) and that added enough sulfate to my water to cause scaling (white flakes). The flakes, when tested against diluted MA, would not fizz but very slowly dissolve. If they were calcium carbonate scale, then they would have fizzed like crazy. So, as you can see, concentrations matter a lot.
It not usually hard to figure out why scaling occurs. In those pools that have scaling from the cell, even if the bulk pool water is “balanced” according to the LSI (or CSI, doesn’t really matter which you prefer), the water may not be balanced inside the cell. Thus, if the TA is a bit too high and the CH is on the high side, scaling is much more likely. Also, scaling is far more likely in a cell that is run at 100% or near that output than a cell that is run at lower output but for a longer period of the day. One way to compensate for pH rise inside the cell is to add borates to the pool water. Borates act as a high pH buffer and have their strongest buffer capacity as the pH nears 9. So, if enough borates are present, the pH of the water inside the cell won’t go much above 9.
