waterbear said:Michael,Michael Silvester said:In Australia, we run our salt at between 5000 - 6000...
So if your cell reading is right...I think you need to
run higher salt and turn your down to 50%
Take Care,
Michael Silvester
Here in the states most of the SWGs run at about a 3000-3500 ppm salt level with the exception of a few (Zodiac, WaterMaid, and Pool Ex come to mind), that run at the higher levels you are used to in Australia. This is the way the units are designed to run and many of them will even cut off and stop generating when the salt levels get above about 4500 ppm. The Goldline units in question in these posts run at 3200 ppm and WILL cut off at salt levels above 4500 ppm and generate a high salt error.
Wow...That's low! We've got SWG's that you can run right up to 13000.
Almost every cell here has a min of 3000. That's amazing. You guys
need to catch up
Take Care,
Michael Silvester
