I have to drill (5/32") out the black plastic injector every 10 days or so due to plugging with the same sort of white deposit that plagued my prior liquidator setup.
The removed deposit dissolves in water acidified with Muriatic acid.
Diluting the bleach with water into the Stenner from 10 to 5% didn't seem to help. Bleach is 10%, HDX brand from Home Depot. OSH equivalent has same effect. Both claim "Calcium free."
The injector is at the top of straight section of 2" PVC return pipe to pool.
Stenner peristaltic pump is model: 45M1, 3 gallon / day set at 7.
Since the bleach in the Stenner black plastic tubing only gets this deposit near and at the injector, there must be some reaction with the pool water that forms the local deposits.
My recollection is the problem worsens with increased temperatures. Perhaps because solubility of some salts DECREASES with increasing temperature? Or the pump is running longer. Problem occurs in 50F water and up. I also believe this problem began many months after installing the Stenner pump in 2018.
Of course, I use the BBB method. CYA: ~40, TA: 80, CH: 320, pH 7.7 (tap water is over 8.3).
Anybody have any insights into taming this beast?
Thanks much!
Thanks much!
