I have the Pentair IC-40. Recommended salt level is 3600 per Pentair. The reading I get from the unit itself fluctuates between 3700-3900. When I use the Taylor K-1766 I get 4200. Repeatable with 2 different test kits. I know TFP recommends running a couple hundred higher than the optimal, but I believe 4200 is above the recommended range for my MasterTemp400 with copper heat exchanger. Would I ideally want the salt about 3800 verified by the Taylor test?
Thanks
Drew
Thanks
Drew
