- May 3, 2007
- 18,089
- Plaster
- Hayward Aqua Rite (T-15)
First, the pool pilot is not intended to have two bypasses. The picture I showed already has a bypass (clear blue bottom fitting) and you are trying to bypass it again which will create problems with flow rate. So the grey bypass valve should always be closed.
But the pressure is still a bit of a puzzler because it should not be that high with dual return lines. What size is the plumbing?
