Hi,
I'm thinking of converting to SWG. I have Jandy automation and Pentair VS Intelliflo pump. For easy DIY I'm looking at Circupoll RJ series. I have two possible location. The first being right after the heater but I would have to put the flo sensor before the cell. The second is a tight spot right before an actuator. I have just about 8" of space in the gape and will use a vertical installation kit.
Which one would you recommend? Do I need to worry about how close it is to the heater? I'm assuming I don't need a check valve either way since gravity is working in my favor.
Heater:
Right before actuator about 8" (remove inline chlorinator):
Thanks!
Heater:
Thanks!
