Hi,
My 24,000 sq ft ingroud pool has two skimmers and one main drain and several return jets. Recently I observed air bubbles in both return jet and pump strainer. So this implies the issue is somewhere before reaching the pump(or the pump itself - but I've ruled out the case, see below).
The experiments:
(1) If I use the return line diverter valve to shut down the skimmer return line(the main drain return is still open), then there is no bubble in the pump strainer nor the return jet. I guess this rules out the main return line leaking, right?
(2) Then if I restore the return line diverter position(half main drain + half skimmer) but close the caps inside both skimmers, then there is no bubble. So this rules out the skimmer return line leaking, correct?
(3) If I open either of the skimmer cap, then the bubble comes up in both the pump strainer and the return jet.
Now I can only think of two things:
(a) Is the weir door stuck so that not enough water gets filled in? No, because the issue remains even if I remove both weir doors.
(b) Is the water level low? I don't think so since the water level is about 2/3 or more in the skimmer.
Could there be any other reasons? What should I check next?
Michael
The experiments:
Michael
