- Sep 21, 2007
- 121
- Vinyl
- Hayward Aqua Rite (T-15)
One of our neighbors passed away this summer. Her family knows nothing about pool care, and used a pool company to maintain the pool until the estate is settled. The pool company used a large amount of stabilized chlorine to fight an alge bloom, and her CYA was through the roof. With the help of the great people on this forum, I helped the pool owner (PO) by doing a partial drain/refill which was enoaugh to bring CYA down to about 60ppm. This in conjunction with a SLAM got rid of the algae, but CYA was still higher than recommended.
In mid September, the PO had the pool company close the pool, and I recommended they lower the water as low as possible, so that in spring the refill would dilute the CYA as much as possible. The pool cover is a new plastic sheet supported by water bags around the perimeter. The water bags have two bladders along the length and the PO recalls that some of the water bags only had one of the bladders full of water.
I live in Southern Ontario and the weather has been very inconsistent. We got a couple inches in early November followed by temperatures over 20C (70F), and in mid November had another snow storm. During the 2nd snow storm (about 2 months after closing the pool), the pool cover was pulled into the pool along with the several water bags. When the cover was pulled back, quite a bit of debris went into the water, and the water level was a bit below the floor of the shallow end. The pool company (and I) suspected a leak had drained the pool under the cover and the cover pulled itself into the pool under its own weight because it had no water to support it. Upon inspection, the pool company could not find an obvious tear in the liner and advised the PO to raise the water level to just below the jets, and added some chlorine (stabilized chlorine UGGGH!) to get the clear the water so that a leak detection test involving a scuba diver could be performed. All the plumbing has been blown out and capped and the pool pump is removed so there is no way to get water circulation. Over the past week, the water visibility is clearing up, but the water level has not dropped at all, so we're not even convinced there is a leak. The pool liner is 10 or 11 years old.
Winter is coming with air temperatures dropping below freezing at night.
I am grasping for other theories how the water could have dropped.
The only other two scenarios I could think of was that
a) at close, the water level was dropped much lower and the cover was not floating on the liner at close, and it eventually fell in,
I highly doubt this as I have a photo of the cover installed which doesn't show any sag in the middle.
or
b) I'd expect the pool company closing would not leave less than a foot of water in the shallow end. Could a foot of water evaporate through or around the cover?
As overnight temperatures drop, the water temperature is much warmer than the air temperature, which will promote evaporation. In my own pool, I get a couple inches of evaporation in September.
If it were my pool, I'd let it sit until the spring and figure it out then, but the PO is desperately trying to get this resolved ASAP.
Any help/advice would be greatly appreciated.
or
