OK you chemistry experts...
FC: 7.5
pH: 7.7
TA: 70
CH: 600
CYA: 50 (slowly going to 70)
water temp: 84
CSI: 0.12
City Water:
TA: 130-150 (depending on lake levels)
CH: 150-180
Questions:
thanks for any guidance!
FC: 7.5
pH: 7.7
TA: 70
CH: 600
water temp: 84
CSI: 0.12
City Water:
CH: 150-180
- I understand that TFP promotes a slightly negative CSI with a SWG.
- I also understand that with a SWG, pH tends to drift up.
- With evaporation, i am gaining roughly 40-50ppm CH and gaining 20-40ppm TA monthly.
- I am (currently) adding 5 cups of MA to lower pH and TA about once every 4-6 days.
- With my current rate of CH gain, and constant lowering of TA, it would require me to keep my pH at 7.5 or lower to keep in the 'slightly negative' range.
- As the pool cools in the fall, the CSI grows increasingly negative, so (typically) i allow the pH to drift up a bit more.
- If i refill now, and i plug in the lower CH numbers (400), and the lower water temp (60), the winter CSI tends to get very aggressive.
- If i do not refill now, i am feeding MA very often to try and keep the CSI (at least fairly) close to 0.0
Questions:
- Would you refill now and adjust pH and TA for the winter to keep it more neutral?
- Would you wait to refill until spring before i get more CH creep and ride out the winter with current levels? i.e., less chance of aggressive water with higher CH levels.
