Greetings,
I have had a new HotSpring spa (325 gallons) for a little over two months now. The new spa replaced an old spa that I had for about 15 years. When I got the new spa I purchased a Taylor K-2006C test kit, because my old Taylor K-2006 test kit was running low on several reagents. I also purchased the Taylor Deox reagent (R-0867) so that I can accurately measure combined chlorine and MPS.
The new HotSpring spa has no bypass filtration and continuous circulation, with an ozonator that (I think) operates 24 hours per day - at least there are always bubbles produced - whether the corona discharge tube is on constantly I am not sure. It also came with a silver ion cartridge, and HotSpring is now recommending the low chlorine regime with these spas, utilizing a weekly chlorine shock (dichlor) and daily MPS additions. I use the spa daily when it's not raining, and I am often the only person in it. I test the water at least twice a week and adjust the parameters as needed. Adjustments and the weekly 10 ppm chlorine shock usually occur on Saturdays. Here are the test results from today:
Temp - 101F
pH - 7.8
Alkalinity - 70 ppm
Hardness - 150 ppm
TDS - 1470 ppm (442 scale)
FC - 2.2
CC - 1.4
MPS - 10.6
CYA - 100
All of these test results are believable and in line with prior results, except for the FC, CC and MPS values, all of which are unexpectedly high. I last added dichlor 4 days ago, and the FC / CC levels yesterday were 0.2 ppm and 0.4 ppm respectively. I added 2 tablespoons of MPS last night after using the spa for about 30 minutes. After the spa water circulated overnight, I expected the MPS level to be around 4 to 6 ppm, and I expected the FC and CC readings to be very low if not undetected.
I used my old K-2006 kit to repeat the FC and CC tests, and the results were confirmed. I used a BioGuard test strip, which indicated no FC. The water is now and has always been crystal clear, with no odor of chlorine or chloramines.
Can anyone suggest what's going on with the chlorine tests today?
Don
Temp - 101F
pH - 7.8
Alkalinity - 70 ppm
Hardness - 150 ppm
FC - 2.2
CC - 1.4
MPS - 10.6
CYA - 100
Don
