Hi All,
The pool i have has a bench with two built in spa jets, to control the air for the jets theres just a pipe sticking out the ground right behind them with a slit that someone had cut out to draw in air. I taped it up for now until i get a permanent fix.
The question i have is whats the best fitting i can use with this pipe to be able to control the air going to the spa jets, is a simple spa air control valve what im looking for or is there something else? Is there anything remote i can use as well so i dont have to walk out there to turn the valve every time i want the spa on?
Picture attached for reference and the spa jets are hooked up to my return jet plumbing with a three way valve at the pool pump for control.
Thanks!
Thanks!
