- Jul 14, 2019
- 56
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
FC 9.5
CC 0.5
pH 7.5
TA 80
CH 100
CYA 60ish
Salt 3400
My interpretation (please please correct me if I have that wrong!!) and My questions
FC: My FC is a little high. The SWG was just installed last week and we are still figuring each other out. That needs turned down another step. It has been staying around 9. I will probably have to put the SWG back up as the weather heats up.
pH: pH always looks like 7.5 to me on this Taylor block test thingy
TA: this was staying at 100, but I did a few doses of the wrong kind of muriatic acid, and it came down to 80. My muriatic acid came from paint section at Lowes and is a mystery % and low fumes. I need to get something else. Is it worth trying to get that down 10 more points to target or should I just wait until pH actually needs lowered to dose acid again?
CH: We have the heater set, but won't be hooked to electric until Monday. I know the CH probably needs to be higher for the health of the heater. We have fiberglass. Our SWG is doing such a great job that I dont want to dump shock in to work on calcium. Is this a priority and how do I fix it?
CYA: Man, I dont even know. its somewhere between 40-60. If I do the test I read it between the 40 and 50 line. But when I compare to the standard, its gotta be 60 or better. Since Im not having chlorine issues, should I worry about this now?
Salt: The PB put in less then was indicated we needed, but it sits at 3400-3600 when I test. I guess its ok for it to be a bit high?
THANK YOU!!!
CC 0.5
pH 7.5
TA 80
CH 100
CYA 60ish
Salt 3400
THANK YOU!!!
