- Feb 14, 2022
- 39
- Vinyl
- Hayward Aqua Rite (T-15)
Hello,
First time taking over the pool work myself this year. The last three years were "The last year we hire someone to do it for us". My pool in NJ is currently closed and covered with a mesh cover. Last year when the company opened it, the water was crystal clear and looked ready to swim in. This year, they did not vacuum before closing it due to "Its a mesh cover and stuff will get in anyway". Well, on the weekend I pulled up a corner to take a look (Still about a month away from opening) and things were very leafy and green. I took a water sample and tested it and here are my results.
The cya test was clear all the way to the top of the tube so its less than 30. I did not do the full chlorine test, just the quick one along with the PH test, but the water was perfectly clear, no signs of yellow or any color change so it's probably 0, especially with no CYA.
At this point, I'm assuming there is nothing I can do until I open the pool and can run the pump. I'm guessing that I will just need to SLAM it once opened and go from there.
Last year's opening
This year's under the cover peek
Last year's opening
