SHort version- cover was torn and didn't get pool covered over winter- NEVER AGAIN will that happen.
I went from the nastiest-swampiest- green algae slime soup to a beautiful blue color in 15 hours. I was shocked and so excited!! Fast forward to a week and half later. Water is beautiful color BUT it is SOOO cloudy. My pump didn't work properly for the first 48 hours during the slam. ( I found and fixed an impeller clog thanks to TFP
). After getting that fixed and now (I think- I feel like pump is actually on a recirculate type cycle and not actually filtering. When clogged there was super low water return. Now, it is like a whirlpool jet coming out of return. I don't have a recirculate function tho. Maybe I just feel it isn't working because water is so cloudy. ?) I am actually filtering water- I still cant get chemistry right and know if I go to the money pit pool store - they'll mislead me and try and put $500 worth of chemicals in my basket.
Did SLAM for 4 days. Passed OCLT (now I have CC and TC) but H2o remained cloudy. Added FLOC (only used 5lbs when should have used 7 lbs.) These were my results Friday- made amendments and now these are results today. Please help- what would my TFP PRO's do to this water (even if it means having to put in something other than BBB- I'm ok with that as long as TFP Moderators tell me and not some 20 yr olds with no experience at a pool store. haha
TODAY
FC= 0.5
TC=1.5
CC-0.65
pH- 8.0
CH-57ppm ( thought it would have raised after I added liquid calcium- apparently I didn't add enough![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Alk.- 107
CYA- 20
FRIDAY-
FC-.0.75
TC=1.5
CC-0.5
pH-7.2
CH-52
Alk=90
CYA-30
I didn't add water- so, where dd my CYA go? I tested with the Taylor kit you suggested. I see I need to increase calcium hardness, get pH down, slam again bc my chlorine levels aren't staying
up enough to be killing everything (and, obviously it is working on something in pool still). How could I have passed the slam OCLT and still have these results later and water not clear? Ohhhhh, I don't have the time or energy for this right now. PLEASE GUIDE ME!!!!!
Thanks Michele
TODAY
FC= 0.5
TC=1.5
CC-0.65
pH- 8.0
Alk.- 107
CYA- 20
FRIDAY-
FC-.0.75
TC=1.5
CC-0.5
pH-7.2
CH-52
Alk=90
CYA-30
Thanks Michele
