What kind of pool light is this?
clock245
6
OKC
Hi, I'm hoping someone could identify this pool light. I tried searching for it, but none seem to look like this. I would assume it was put in around 2012. I'd like to replace it with a multi-color light that will run off of my Pentair Intelliflo 3 pump (011075). Do you have any recommendations for something that's reliable and easy to service? Someone recommended a spa electric to me, but I'm unsure which one i should get. That said, if there's something better I would love to know---I really like wifi control and bells/whistles, if that helps! Any links would be greatly appreciated!!!
Looks like a Jandy nicheless light. They literally just un-thread from the fitting they are in. It is a 1.5" female pipe adapter, so any nicheless light that your system can control and will fit into the length of pipe behind the wall will work.
Search for "Jandy nicheless light" and "Jandy nicheless light tool" for light replacements and tooling.
Thank you so much!
I am interested in the spa electrics R1 as a replacement. Do you think that would be a good brand/model for reliability and ease of maintenance down the road? If it helps, it is a vinyl pool. Also, i would imagine this Jandy installation had to have a transformer between the main power and the light---do you think that woudl be the case?
