what kind of caulk?
drrayb
62
toronto, ontario
Hayward Aqua Rite (T-15)
in ground steel wall vinyl liner pool, in ontario, canada
we poured a new deck this year (pic attached) and kept the existing flagstone coping, with a foam expansion joint in between
i torched down 1/4 to 1/2 inch of expansion joint all around to make room for caulking. my concern is, there are areas where the flagstone due to natural waviness and concrete dont line up perfectly and one side is higher than the other.
should i still use self leveling? or better to get ordinary caulk and work it flat?
advice is appreciated, even moreso if you'd like to suggest a specific product from homedepot.ca, because we dont have as wide availability as you guys do in the states.
thank you!
