- Jul 6, 2022
- 26
- Vinyl
- Hayward Aqua Rite (T-15)
New owner here, drinking from firehose on pool stuff. Trying to figure out what this is on the side of the pool. I have had people tell me different things, one said it was an “alternate” return port (or something like that) and the pool needed to be filled to keep it underwater, but another guy said it was an optional vac/accessory fitting.
However, to get this port fully below water I would have to fill the pool so much that the level would be about 2 inches above the top of the skimmer opening (skimmer flap completely submerged).
On the suction side of the pump, there are two lines coming from the pool. One has an old gate valve, the other has no valve. Turning the valve end to end seems to have no effect on anything, pump seems to pull from skimmer regardless. The other issue is that I’m trying to recover this pool’s water and it’s currently so cloudy (can probably see in pic) that I cannot tell if there is a deep water or any other vac or lower ports in the pool. I'm trying to figure out what this port is and what I'm supposed to do with it. The prev. owners left a Dolphin bottom vacuum so I was thinking this is either the vac port or there is another one somewhere (unless they were attaching it to the skimmer).
