The vitals:
Day 8 of SLAM, FC topped off to 11 morning and dusk. Brushed 3x/day.
CYA 28 (very top of Taylor test vial)
CC usually 0, sometimes 0.5
OCLT down 3 to 4 ppm
Taken pre-SLAM:
PH 7.8
TA 60
CH 80 (adjusted to 250 during SLAM but not yet confirmed via test result)
Temp 66
I have very tenacious algae at a depth of 3ft (likely the winter ice depth) to about 6ft. Pool is 8ft deep. This is after 8 days of SLAM.
I'm continuing the SLAM as the FC is still reacting but visual progress on the algae is very slow. Brushing does not produce any visible satisfying clouds indicating progress. Water is now crystal clear.
Is there anything else I should do to speed this up and insure it doesnt cone back? I've never had algae like this before. It's an unusual year as about 75% of my water had to be pumped out to accommodate a crazy amount of snow and snowmelt.
I'll tell ya, lowering the water level so it doesn't reach the skimmer in 15F through a ft of ice buried under 6ft of settled snow is neither easy nor fun. Do not recommend.
But nothing froze and cracked! Woo hoo!
Taken pre-SLAM:
PH 7.8
TA 60
Temp 66
