What is this plumbing puzzle?
desertOasis
Active member
Jul 30, 2022
31
Palm Desert, CA
This pipe and weird end cap comes out of the ground behind the filter housing for our pond/waterfall. Note that one of the 6 caps on top is missing (?). I became aware of it when it started spraying a jet of water into the air. It is definitely part of the pond plumbing; when I turned off the pump it stopped spraying.
Is it some kind of relief valve system? I will open up the filter tomorrow to take a look, but it was completely cleaned out and new cartridges installed not long ago.PXL_20250119_000437527.jpg
Mystery solved by coincidence. I thought it was part of the pond pump plumbing. It's actually as YippeeSkippy guessed. It's on one of the irrigation lines for the plants around the house. I didn't know that because water has never come out of it before. I guess pressure finally blew out one of the caps. Maybe during some previous ownership it was used. I plan to just cap off the pipe.
Thanks for the suggestions!
Ron
