I understand HOCl. is the form of chlorine that does the killing.
What levels of HOCl are actually required?
I'm reading different advice in various places. I've read you need minimum of 0.05ppm. But we also hear you need a minimum FC of 7.5% of CYA
Assuming CYA of 30 ppm, that gives 2.25ppm FC, of which ~97% will be bound, leaving 3% of 2.25 = 0.0675ppm of available FC, which results in less than 0.05ppm of HOCl for most pH levels
I'm reading this paper: http://www.lowrycg.com/wp-content/u...h-Free-Chlorine-Do-You-Really-Need-rev-03.pdf
which seems to offer contradictory advice:
Wouldn't you need more than 7.5% CYA to maintain HOCl above 0.05 in most situations? presumably many of us are running satisfactorily at lower than 0.05 HOCl?
You can see that algae are not killed (HOCl >0.05 ppm) with even 4.0 ppm FC when CYA is more than 40 ppm andthe pH is 7.5
If you have 50 ppm of CYA then you need 3.75 ppm FC minimum (50 × 0.075 = 3.75).... By having FC at 7.5% of CYA, the amount of HOCl will be more than the0.05 ppm HOCl needed for algae control.
