Our pool sprung a massive leak and drained itself dry while we were away. When I got home I found the empty pool and our Pentair Versaflo pump running. The leak is fixed and I'm having water delivered. What is the chance that the pump will still be ok? As my wife pointed out, at least it didn't seize. Is there any way to test it in advance without a filled pool? If it is dead, do I need to replace the whole thing ($1100) or can I replace just part of it?
Note that the equipment is below the bottom of the pool so the pump may still have had water splashing around even though there wasn't enough to pump.
