New house, new pool. There's a designed hole between the spa and the main pool. Not sure why it's there as the spa spills over the pool when pump is running. Previous owner plugged it up, I'm assuming to help keep spa hot when using it, which makes sense. However, whatever he used is now a tetanus factory of rust and corrosion. I haven't tried removing it yet, but assume I'll be able to figure that out. Anyone have idea of what I should replace this with? Should I not replace it at all and allow water to flow between spa and pool?
Thanks for the advice.
Spa Side:
Pool Side:
Spa Side:
Pool Side:
