This is my 3rd summer with an in ground pool. The first 2 summers I had minimal issues and a bout of cloudiness that cleared up with a shock treatment. I use a home test kit and test my water once a month at the local pool store.
However about 2 weeks ago I developed cloudy water that I couldn’t clear. The day it started to cloud the chlorine was really low. I tried multiple shock treatments and clarifiers but no luck. The water was just cloudy, no algae growth, no slimey water. I couldn’t see the bottom of the 3 ft shallow end cloudy.
I took a sample to the local pool store to get some advice (I will post a picture of the results). The results showed low chlorine, ph on the low side and sky high phosphates. I added their recommendations and after a week the pool was still extremely cloudy. I know it will be asked I typically backwash my sand filter weekly, but during this episode I backwashed and rinsed every morning. Also I replaced the sand mid summer 2022 with zeo sand.
After some googling I decided to try a flocculent. About 24-36 hours after the water was cleared. I then vacuumed to waste 2 times cleaning the flocculent from the bottom. Pool still ended up a little cloudy after the vacuums. I then double shocked and 3 days later the pool is now crystal clear.
Today I took another sample to the pool store and the results are very similar to those a little over 2 weeks ago. The phosphates still show 3000 even after over 2 quarts of phosphate remover. My question for the experts is, what caused the cloudiness? The water samples are similar and one was extremely cloudy water and the other sample is crystal clear.
Here is a picture of the test results. The result column is from today.
