We bought a house with a pool, and I try to DIY most things in my life so figured I would attempt pool maintenance as well. I'm getting a little discouraged so far. I've done some reading on here and ordered a taylor K-2006c test kit that just arrived. I went out to do some initial testing. The first thing I tried testing for was CYA, and if I did it correctly I got a reading of 100. Can that be right? My water sample was already fairly cloudy. That has to be accounted for already right?
Before I found this site, I went off the advice of some friends with pools. I opened the pool on Sunday, added 3 one pound bags of HTH shock on Monday. Then added another two bags on Tuesday and 4 pucks of trichlor tabs. Yesterday I discovered this site and saw that liquid chlorine is better than shock? So I added a gallon of 10% chlorine from the hardware store. Yesterday before adding the liquid chlorine the pool had actually turned from dark green (on Sunday) to a nicer teal/aqua color. It was still very murky/cloudy yesterday though. Today it started turning back to green though. So I'm wondering if the liquid chlorine made it worse somehow?
I also tried testing the chlorine levels with the kit I just got. I figured I'd do the 25 mL sample to get an accurate reading. However, when I went to add in the scoops to turn it pink, I couldn't really get it to turn pink. The kit says to keep adding the powder, and I think it finally started to turn a very light pink by the 6th or 7th scoop. But it shouldn't take that much right? Am I doing something wrong with these tests?
I'm on well water, so the idea of draining half the pool and refilling it has me worried I would run the well dry. We just moved in a few months ago so I don't have a great idea how large the well is. Is that something to worry about?
