Hi Folks. What am I doing wrong? As you can see from this short video on youtube, everything is fine until I go to attach the vacuum plate and hose. I immediately lose prime. All the air is out of the hose. After watching the video any ideas? One thing to add in the video is that the vacuum still has some suction. I was able to pick up leaves on the bottom but the pump is all air and splashing water. Could the 2 seconds it takes for the vacuum plate to have the hose attached be causing this? Should I take the weir door off and slide both the vacuum plate and hose together through the skimmer instead? Thanks for watching!!!
Jun 11, 2017 - YouTube
