Hi all,
I am experiencing some weird issues with my pump recently and was hoping to get some insight on what may be going on.
I had an algae bloom a few days ago so am in the middle of the SLAM process.
I have a Hayward Super Pump which has been pretty rock solid in the past. Recently, though, when I turn the pump off, I hear air hissing in the pump basket and a little water squirts out the sides. I checked the gasket in the pump basket and I went ahead and replaced it making sure to thoroughly apply some silicone based lube. I also replaced the pump basket itself because of a crack.I am also seeing air bubbles in my return jets.
The other thing I am seeing is a delay in when the water comes out when I start a backwash. Before this issue started, water used to come out immediately when I turned on the backwash, but now I am seeing a delay of up to a minute before the water flows out.
Any insight on what is going on here?
Thanks.
Thanks.
