- Jul 3, 2019
- 425
- Plaster
- Jandy Truclear / Ei
I guess with all the splashing and big waves, the water going into the skimmer, then forcefully pushing the skimmer weir door up against this piece of plastic finally gave way and cracked the skimmer frame. This is causing the weir door to stick outward into the pool
Where it is cracked we can pull the this plastic lip away about an inch or so. It is attached on the left-hand side.
What’s the best way to fix this? Some JB water weld?
