Weepers, Efflorescence, and other Concrete Pool Shell Problems
The one problem with this is "you can waterproof concrete" it costs a little more but can easily be done.. I am going to be doing it from the start... With waterproof concrete there is no way for all those things to happen :)
Recommended for:​
  • Reservoirs
  • Sewage and Water Treatment Plants
  • Secondary Containment Structures
  • Tunnels and Subway Systems
  • Underground Vaults
  • Foundations
  • Parking Structures
  • Swimming Pools
  • Precast Components
Advantages​
  • Resists extreme hydrostatic pressure from either positive or negative surface of the concrete
  • Becomes an integral part of the substrate
  • Highly resistant to aggressive chemicals
  • Can seal static hairline cracks up to 0.4 mm
  • Allows concrete to breathe
  • Non-toxic
  • Less costly to apply than most other methods
  • Permanent
  • Added to the concrete at time of batching and therefore is not subject to climatic restraints
  • Increases flexibility in construction scheduling
