- Apr 22, 2024
- 9
- Plaster
- Compu Pool CPX / CPSC36
I have a Hayward 244 sand filter, worked fine for years. this year when it is in the filter mode I have strong water pressure in the jets for about 30 minutes and then it drops significantly. When I switch to recirculate it runs great without dropping pressure. I have checked for suction side air leaks, found one and repaired it, and replaced the sand. the lateral assembly look good. I saw a post on a similar problem but with a cartage filter. I don't know what to look for next. My local pool supply store does not have any suggestions. I know this is a common problem but I could not find it. Thanks in advance for any help offered.
