So my above ground resin pool was just installed. It came with a 200lb sand filter and a Waterway 1.5hp two speed pump. Model # sd-15-2n11mc. I'm not having any luck finding what I'm looking for and I'm not an electrician.
Can I wire this thing to a timer to run a program that has the pump turn on low speed for a few hours, turn on my SWCG (Circupool SJ-35) while at the same time turning the pump to high speed for a certain number of hours, then finally turning off the SWCG and going back to low speed for a few hours? The pump came with a standard three prong plug and a manual switch for high - off - low.
This install has been a cluster and much more of a headache than expected. Any help or ideas? Thanks all.
