Waterfall and main pump running together
jcfd129
2
Flower mound, tx
We have a main pump and a waterfeature pump We had a power outage and after that they both run with the main pumps schedule. It used to not be that way. All jandy gear with aqualink. 1 year old set up. Not sure what would have changed. TIA. -Matt
Welcome to TFP.
Have you checked your schedule on iAquaLink? Can you post a photo of your schedule screen?
Sometimes a power outage can mess with the date and time as well.
I will take a look at that. What is strange is that even in service mode when I select the main pump it will fire up the waterfall pump also. It didn't do that before. It had its own button. Also when I get on the aqualink app it cannot manipulate the waterfall like I used to. I am thinking gotta be something with the dip switches but don't see how they would change.
This is strange, especially when in service mode. I wonder if something got fried in the power outage.
With your AquaLink panel open and the cover off, show which relays the main pump and secondary pump are connected to.
You still have power to both pumps but for some reason they activate together which is something on the PCB.
