- Apr 22, 2019
- 424
- Vinyl
- CircuPool Core-55
Hello! Well, we replaced our liner a few months ago. With that came brand new water and everything had been crystal clear and perfect since then. I had been using liquid chlorine from Atwood’s, 10% specifically meant for pools. But they ran out, and the absolute only bleach I could get my hands on here was Great Value from walmart. I think it is 6-6.5% or so. I added that and the next morning the pool was hazy.
The temperature outside was also extreme during this time, 102+ degrees and my pool was baking in the direct sun all day, so I was having to add even more of this weaker bleach to maintain level, and the pool just continued to cloud up. In addition, I started noticing some yellow-orange staining on the liner in a few spots. I was horrified because we’d finally seemed to have dumped out iron issue when we changed the liner!!
Finally able to get some 10% pool chlorine the other day and start using that. In addition the temperatures dropped to the 80s again. The water is still super cloudy, but all the yellow-orange has gone away. The water is blue but has a white haze. You can barely make out the deep end.
At this point I do not think it’s algae but something to do with the Great Value bleach, as that is when it all started…
Passed the overnight test two nights in a row. My test results:
Chlorine: 6
CC: 0.5
CYA: 40
TA: 40
CH: 25
PH: 7.6
Temp: 92
What to do?
Chlorine: 6
CC: 0.5
CYA: 40
TA: 40
CH: 25
PH: 7.6
Temp: 92
What to do?
