Hi all. So I got my algae bloom under control and the water looks great - nice and clear. I shocked the Crud out of it for about 2 weeks and due to some local supply chain issues, have been forced to let the chlorine fall back to nothing. So I decided to do a full water test and get your opinions in any balancing to do before resuming chlorine.
As I said, no free chlorine for this test.
pH - 7.6/7.8
TA - 80 PM
CH - 70
CYA - 30
I figured I should bump the CYA slightly, try to get closer to 40 or 45. Also my pH was higher (around 8) when I stl had 3-5 ppm of F-Cl in the water, so wasnt sure if I should lower just a bit so when there is consistently around 5 ppm free chlorine it's still around 7.6.
Thanks all - any other suggestions welcomed.
pH - 7.6/7.8
TA - 80 PM
CH - 70
CYA - 30
