Water Level Sensor
joelans
15
South Carolina
Does anyone know of a wi-fi enabled water level sensor? Not an automatic leveler - just a sensor.
I have a water fill line attached and run via a Rachio WiFi hose timer, so I can turn the water fill on/off remotely.
What is like is some type of water level sensor to notify me when the water level gets to a certain minimum level, so I then know to turn on the water fill.
There have been products like that around but they all die as they cannot make money.
You can build such a device.
Float switches are being discussed here - Featured - Operation of Infinity Edge and Zero Edge Pools
Then you need an IOT device that will send you an alert when the water level drops.
This used to do it....
and maybe this will be born...
