- Nov 12, 2017
- 11,903
- Plaster
- Pentair Intellichlor IC-40
Mine is actually an auto-leveler. In addition to the filler there's a drain pipe that is also adjustable. So I can control both how low and how high my water level gets. I never have to worry about too much sun or too much rain. But...That’s exactly the one I have. They are incredibly reliable. I have no idea why pool builders choose to install the toilet bowl ones. My one thought was that maybe you can make the fill pot smaller with the toilet bowl version and so there’s less impact on the pool design by not having a big fill pot sitting on your deck somewhere but I really can’t believe it would save that much space.
When the filler fails on, it just pumps water into the out port, and unless I watch it periodically, it could do that for months unnoticed. Well, at least until the next water bill shows up, or the one after. So my new water meter will help with that aspect, too.
If the two are properly adjusted, far enough apart, then I can just observe the edge tile. If the level gets higher than expected, that would indicate the water is up to the out port, revealing a problem. I've just been lax about it this last year, and now realize that first replacement valve was no better than the original one in terms of life-span, so I have to be more diligent. Both in observing the level and in pro-actively replacing the valve.
Point was, the well is narrow and there's more than just the toilet valve in there. I doubt I could retrofit the type you guys have, so that might be why it was originally designed with the more vertically-shaped valve.
