So I noticed this year when opening the pool I was losing water around my return jet. I also notices that the rubber gaskets were worn so easy fix I'll just replace them. When I pulled the fittings out to replace them I noticed that around the return jet the liner is torn and in a spot missing completely. So this makes me think that the return fittings aren't leaking, but water is getting behind my liner and causing my outer shell to rust.
I thought about putting a piece of flex seal tape on the areas where the liner is missing and reinstalling the return fittings. Any other ideas?
